1oo LC V8 2uzfe
germanische
2ooo
v8
2uz-fe
Dear folks, any common advice for charging trouble, right from one of the nother moment quit the LC charging.
If i pull negative from batzery, engine turns off....
Fuses seems lock fine, a bit corrodet right at the battery side/ 7.5, but couldn find a alternator fuse at the drivers side kick panel.
Owners manual says, there should be a fuse.
But is there a common problem i can adress first?
What is the voltage across the battery posts while the truck is running? Anything less than 14 volts and the alternator is not charging. That should be your first step.
Today i switched coles and regulator. Still not charging
Multineter Battery 12. Isch Volts. When the car runs
Start here, then do this and see what your results are. However, to properly "test" the alternator you have to remove it. At that point why not invest in a DENSO reman and replace it? Your time has value, and we are a week into this troubleshooting.
