1KZ-T fuel pump adjustment
Slovakia
Hi guys,
I need help with adjustment mechanical fuel pump on my 1KZ-T engine,
Which bolt on fuel pump is adjusting fuel load
I planing instal intercooler but before i want try to adjust more fuel to engine and tr how it will ride
thanks
Does this help..Straight out of the 1KZT factory manual.
Yes I thought that, but i was not sure, thanks
And one more question
What does it mean when smal red turbo light comes on under rpm tachometer ?
'Overboost' on the HDJ81 it's set to 15psi... Typically hit it in the winter if I am going up a hill.
Hi there does anyone know what is the part number for mechanical fuel pump of 1kz -t??
I think there are a few part numbers depending on the vehicle the engine was in. Here are a few to get you started. Toyota: 22100-67040, 22100-67050, 22100-67060, 22100-67090, or Denso: VE4/12F2100RND885.
Thinking of putting one on your 2LT-II? :) Apparently it is a hard to find and expensive pump though. In my case I was thinking I could adapt a pump from a 1KZTE which is easier to find. I think the 2LTE computer could run it....
I'm thinking to swap the 2lt for 1kz-t .I found an 1kz-te " cheep " and i'm trying to find a fuel pump to run it
