1hz injection pump/firing order
Benghazi, Libya
Got my injectors and pump tuned then reinstalled. I had trouble figuring out which lines go where on the pump, until I found a post by Rosco in another forum. Might help someone else, since it doesn't mention it in the fsm. Still a newbie but learning.
Must be in the FSM because thats where I got the info. Or maybe I copied it off another 1HZ, too long ago
Ya, your post was from 2007. After searching all over online it was the only source I found for the firing sequence on the injection pump. The closest thing I found in the fsm is a vague diagram, which I tried implementing, and got wrong
Its a safe bet that if you have to bend a line to fit even slightly, its in the wrong spot, unless of course they were bent on diasassembly.
The diagram in the FSM is on page FU15 .
Yes, the previous owner pretty much had them bent outta shape. The bigger bracket holding the lines together near the pump was also missing. Being a novice, I didn't wanna take any chances, and wanted to go by the book. I'm undoing some sloppy work that has been done to it, and hopefully have her back in shape.
I don't know if we're looking at the same manual, but the one I'm looking shows 1hd-t engine on fu15.
I got it from the on line manual I downloaded. I will have a look in my paper manual later. It was under the part for installing the injector lines.
In the online manual I have ,your diagram is on FU9 and it shows the 1PZ on the same page.
