1HDT Head modification
Calgary, AB
Recently suffered a catastrophic failure minutes before firing up the engine after a complete rebuilt. before the install of the cam, it was plastiguaged twice to insure proper clearance.
The damage is localized to jornal #7 only.
I wounder if anyone attempted to fit cam bearings to the 1HDT head?
The first two pics are of the jornal and the third is of the cam.
Plan A... I would be more inclined to weld both the head and cap up, line bore it and start again....
Plan B... you may be able to do a more brumby fix by sourcing a cam bearing from whatever that has a noticeably larger o/d than the original cam bore and a smaller i/d than the original cam journal.... line bore the buggered cam bore to the new size and grind that one cam journal to the new i/d size.... don't forget to drill an oil hole in the new cam bearing and allow appropriate clearances....... fairly redneck tho.
Plan C... get another head.....
Have you figured out what actually went wrong..... was it just bad clearance measurement or is there some other underlying cause....
