wussyPup
just another ex-VI Cruiser
- Joined
- Apr 27, 2005
- Threads
- 142
- Messages
- 1,191
- Location
- Langford, British Columbia, Canada
- Website
- www.flickr.com
1HD-T from 1990 HDJ81 with 136,700 Km.
Finning analysis of sample of Esso XD3 0w40 with 4,700 Km.
Action Required
Wear Metals (ppm)
Oil Condition / Particle Count (ct/ml)
Could the high levels of Sodium be leftovers from the higher detergent oil used in Japan?
-Steve
Action Required
Code:
ABNORMAL SODIUM CAN BE RESIDUALS OF COMBUSTED COOLANT ENTRY THROUGH CYLINDER(S),
OR ADDITIVE, MISC. SOURCES; GLYCOL TEST IS NEGATIVE. OTHER ANALYSIS READINGS
APPEAR TO BE ACCEPTABLE. SUGGEST TO CHECK OPERATION TEMPERATURES, VISUAL
INDICATORS, COOLANT LEVEL, CONDENSATE, ETC. SUGGEST TO RESAMPLE @ 4500 KMS. TO
CONFIRM & MONITOR. EVALUATION CAN BE RE-ASSESSED WHEN SAMPLING HAS FURTHER
DEVELOPED A TREND FOR HISTORIC COMPARISON.
Wear Metals (ppm)
Code:
Iron 12
Chromium 1
Nickle 0
Silicon 5
Aluminum 3
Lead 0
Tin 0
Copper 1
Sodium 44
Potassium 1
Boron 5
Silver 0
Molybdenum 0
Magnesium 61
Zinc 1389
Calcium 3381
Barium 0
Phosphorus 1265
Code:
Soot 10
Oxidation 15
Nitration 8
Sulfation 20
Water Negative
Anitfreeze Negative
Fuel Negative
Viscosity@100C 12
Viscosity@40C 67.6
-Steve
