1HD-FTE replacing injectors
Belgium
Hi,
A couple of questions regarding the injector replacement on these engines:
- do you need a puller or similar to remove the injectors and copper gaskets?
- for cleaning the seats: what to use and how to prevent debris from falling into the cylinder.
- anything specific that is to be kept in mind/done?
Thanks for the input
I suggest reading the following thread “1HD-T injector removal prep”. Good info, the copper washer puller tool works.
They are not even close to the same. A 1HD-FT and 1HD-FTE are located under the valve cover.
Cheers
You are correct on injector location, however I found lots of relevant and useful information for the task. Especially information on tools which were requested.
