Good day legends
Long time lurker, first time posting on this one because I've hit a specific question I can't find a definitive answer to and I know this community has forgotten more about LC100s than most people ever learn.
I'm doing a 1HD-FTE engine swap between two HDJ100s. The donor car is a later 5-speed automatic (A750F) and the recipient is an earlier 4-speed automatic (A442F). Both are LC100 chassis, both 1HD-FTE, so mechanically it's straightforward — same mounts, same bellhousing family.
The donor engine is coming with its matched ECU and injection pump as a pair, which I understand is the right way to go for pump/ECU calibration reasons.
My specific question is around ECU-to-TCU communication:
Will the A750F-paired engine ECU communicate correctly with the A442F TCU — specifically the torque reduction handshake during shifts? I understand these are relatively simple discrete signals rather than CAN bus, but I'm conscious that the signal format, voltage, or pinout expectations may differ between what the A750F TCU sends and what the A442F TCU sends on that line.
Has anyone done this combination, or does anyone have the pinout data to compare the two? Trying to establish whether I'm looking at a clean swap, harsh shifts, or potential fault codes before the engine goes in.
Appreciate any knowledge you can throw at this.
