1HD-FT water injection testing
I get that, but same basic system. It's still an 80, I was curious where he was mounting everything
I'll grab some more pictures for you tonight of mounting locations. But I do have one of my water tank during building the rear drawer system. The pump is mounted on the side of it in between the wheel arch. All the rest is fairly straight forward with 1/4" high pressure tubing run down along the door strips into the engine bay then off to the various injection locations.
Mines really no different to any of the other kits out there apart from the fact I'm running a much higher pressure pump and all the components needed to be sourced individually due to requiring a higher pressure rating than what the kits supply. Even then I've still blown up a pressure switch due to my own error from the higher pressures but with my new one it seems to be running fine with the 9000psi burst rating, lots of head room for error.
