1HD-FT surge light acceleration
New Zealand
Hi guys,
My 1996 VX 1hdft 24 valve has a slight surge around 1500/1700rpm only under light acceleration and seems to be just after it changes into 2nd or 3rd. If I apply more accel it’s fine.
It’s been bugging me for a while now
It seems to get better when the egr is connected (normally disconnected) so I wonder if it’s that? Maybe blanking it off might be the fix.
Could it be the pump or injectors?
I’ve done things like fuel filter, auto throttle cable adjust, removed fuel cap. No difference.
Thanks !
You'd be better served posting this up in the diesel section but my guess is it's likely fueling related. I deleted all the EGR crap on my FT and don't miss it one little bit. How long has it been since the injectors or IP were serviced?
I don’t believe they have ever been serviced, not since I’ve owned it... a lot of money to find out it’s possibly not that... wouldn’t other symptoms be present if that was the case?
Hey guys, I've since blanked off my EGR and I still get a surge at certain RPMs. I notice if I give the throttle a blast (couple of WOT taps) before driving then I don't get a surge for a while...
I'm wondering if this is a sign of injectors need servicing or replacing? Does anyone have any advice? Should I try some injector additive (does this ever work!?). I could just replace them but if it's not that it's a costly exercise.
Cheers
