The past few weeks my truck has started running really rough at idle or low speeds, I did a basic tune up with plugs, wires , cap , rotor and air intake tube just incase it had cracked. I checked for vacuum leaks and didnt seem to find any. One thing i did notice was a small amount of oil in the air intake tube when i was replacing it, and when i plug the flow of air coming from the valve cover vent hose to the intake it runs much better. So i'm thinking i'm getting lots of build up pressure in the engine and blowby. What should i do next as far as diagnosing, am i looking at worn rings or out of spec valves ? The 80 has 254k miles on the clock head gasket was done by PO at 199k at a dealership but i'm not sure if they did any head work besides just the gasket. No mixing of oil and coolant that i can tell and no bubbles in coolant.
