1FZE engine removal
upstate SC
The FSM says that you must remove the engine with the tranny attached. :frown: Is that correct? Is it possible to unbolt the tranny first? :confused: Any tips, hints?
This is in reference to a '96 LX450.
Regards,
Mark
VT,
I took my engine out without removine the transmission. One issue is the tight fit between the firewall and the bolts at the top of the transmission and engine block that attach the 2. The bolts on the sides were easier, as were the bolts on the bottom. I did it that way not just because it was easier, but I would have needed a few mor feet of room than I had to work with, I already had the cylinder head off, I already had the firewall heater hoses off, and after carefully studying the actual truck, and FSM, I decided this would be the best way for me.
I'm not sure that would have been the case if I had not already had the head and heater hoses out of the way. Going back in it was more difficult due to the head being back on before installation, and joining the engine to the transmission was no small part of it.
Patience, time, space, this forum, FSM, and a lot of careful procedure are all your friends in this process.
I'll keep an eye out for your thread.
HTH,
D
DTAYLOR,
Thanks for the info.
I guess my real question is: which way is easier? At first glance, it seems difficult to pull the engine w/ the tranny due to the length of the assembly, weight, etc.
-VT92
DTAYLOR,
-VT92
i agree.
Unless you have a lot of room to work, and I guess there is something to be said for having easy access to ft & rear seals, changing fluid, etc.
Knowing myself the way I do, I would be sending the transmission out for a rebuild while it was out. Which would put any rebuilder at a huge disadvantage because they would not have knowledge of how it performed pre-build.:mad:
I remember thinking it would have bene nice for Mr. T to have put in a removable firewall section right there because it was such a difficult task to loosen and tighten those bolts.
D
FWIW, LOOOONG extension and swivel with a 6 point socket from underneath will get it every time, just like the mini trucks its a PITA first time you do it. the extension route is the way to goreaching the top bolts, lwer the tail shaft of the tcase if you need more room (just remember to put your Xmember back on before disconnecting the tranny/engine) and prop the tranny bell housing up with a jack stand to prevent damage to the linkage.
*B*
I pulled mine as an assembly, and I can tell you that without a forklift or a tow truck, its not worth it. In order to clear the lower radiator support the engine and trans has to be almost 8ft in the air. Not fun to have to work under. A conventional "cherry picker" will not touch it.
*B*
How long is LOOOONG? I have about 2 feet of extension. Will I need more? Did you go through the shifter console or from the bottom?
just swaped engines on my other 80 pulled the engine and left the transmission in place easy job. when putting the engine back in leave off the engine mounts off the block and it will give you and extra 2-3 inches of wiggle room to mate the engine back up to the transmission.
