1fz rough idle while braking
DC
Website
www.instagram.com
these past few weeks, ive noticed a weird new tendency; when i start my truck, it idles fine. i drive off, a few minutes later, i brake for a turn or a light, and my rev counter dances between 250-1250 or some such, ive tried it in and out of gear, same thing. when i stop, or let off and give it gas, it goes back to normal. once its at operating temperature, it wont do it. have any of you seen this before?
sounds like a vacuum leak somewhere- for grins pop the hose off the PCV while it's idling and parked, should recreate the problem. To find the source of the leak try spraying something flammable (carb cleaner, starting fluid, etc) around suspicious fittings and hoses- if there is a rise in RPM you should have found a leak.
HTH
Newbie here- So does that mean if I pull the hose off the PCV while idling/parked and the RPM "flutters" I have a vac leak somewhere? My PCV is making a wierd noise at idle so I popped to hose hose to check for suction and encountered the varible RPMs as described by tblume, but I don't seem to have issues with idling currently.
Take a look at the check valve that is in the brake booster or the hose going to it. When either of those go bad it wreaks havoc.
