Hey everybody,
I’ve got a 1997 Lexus LX450. I‘ve been chasing my tail on some running issues but to get to the point:
What are your MAF read outs? whats the g/s at idle vs say 3000 rpm? What’s the voltage/resistance values? Anybody know if a same year 4 runner maf will work or is the same? Part numbers are slightly different but they visually look identical from what I can tell via online pictures.
And before you suggest it, I tried to get the land tank/wits end upgrade but they’re out of stock. I did even go as far as buying the maf they use and modifying a Bosch maf I had from a different car that still had the screen in it and making it work together but the diameter of the pipe is slightly smaller and I wonder if that affects the readings. My truck has new oxygen sensors (sensors) and a new single cat exhaust. The truck is running SUPER rich to the point where I have replaced the bank 1 (upper) o2 due to fowling out/inop. I get about 7mpg currently with the only modification being 33” tires. I used to get 12-13. I’m going to reset the pins back to stock and install my old maf and see what happens. Then I will try to swap the. 4 runner maf and compare notes.
any help is appreciated. I ordered the four runner maf to see what’s up. Cardone is sending back my old one. They couldn’t rebuild it. I don’t know if that means they think its fine or if its not rebuildable and I need a new one.
I also wonder if my issue lies elsewhere. I smoke tested for vac leaks and only came up with the EGR vac valve. I have not tested fuel pressure and wonder if possibly my Fuel Pressure regulator has failed. But I was getting maf codes/o2 codes originally.
