1FZ Hard cold start
Hi guys,
Recently removed the LPG system on the car so it currently runs straight petrol. Since then, I've noticed when it is under 14C (57F), the car takes a lot of cranking to eventually turn on. The colder it is, the longer I have to crank. Some cases when it's really cold, I crank 3 lots of 5 seconds before it eventually starts.
What is the likely cause of this?
Thanks
Don’t think it’s losin fuel pressure or air leak because if I leave it till the weather eventually warms up, it starts fine regardless of how long it has sat.
Which temp sensor do you mean?
Air leak = weak mixture, rich needed to start when cold.
ECU needs feedback, unsure if this is a seperate sensor to gauge?
Hopefully someone will chime in with other thoughts, very few petrol versions in Europe.
Regards
Dave
Doubled checked the vacuum lines and air intake, still occurring. Doesn't seem like it's completely temperature related. Sometimes when it 20C (68F) it will have a hard time, other times when it's 15C (59F) it will fire right up ... and it only happens on the first start of the day.
The other day was quite bad, cranking but a total of 1 minute (in short bursts of course). It refused to start, left it for 2 minutes and tried again it fired right up.
