1FZ-FE idle speed
My '92 1FZ FE has a mind of its own with it's idle speed. Recently it was running very fast during the warm up. Now it is running too slow and cuts out when warm. What I want to know is if the idle speed is completely controlled electronically or can it be adjusted by an idle speed screw? I haven't tried to adjust it yet as would like to learn from others experience. I'm OK with old technology but the electronic stuff is a challenge so need some help.
Pete
Contradiction in terms: '92, 1FZ
Not compatible. If you have a '92, it's a 3FE. If you have a 1FZ, it's at least a '93.
On 1FZ's, the idle speed is electronically controlled, it has to be repaired by finding the faulty component and replacing it. Get a factory service manual and go through the checks for ISC valve troubleshooting, etc.
If it's a 3FE, I don't have enough experience with those, someone else might chime in here.
Good luck, Dan.
Thanks for the advice. I was expecting someone would tell me 1FZ came out in 93 but when I bought it was advertised as 11/92 model. I dont know if is a build date or first registered date which may be the variable factor?
Pete
Peter,
Regardless of production date, 91 & 92 Model Years had 3FE. Model years from 93 to 97 had 1FZ-FE.
Best is to find out which you have and get a FSM to dig out your trouble.
Dan.
