1F Engine parts/ 3pd / Transfer Case
Kansas City, MO
Website
usacac.army.mil
Parts are located in Seaside, CA which is about an hour and a half south of San Francisco. It was a little cold blooded to start but never failed me. Everything worked as of an hour ago when I drove it around. Parts should be ready to go by the weekend as I’m pulling the engine over the next couple of evenings.
Starter-15
Alternator- 10
Fuel Pump-
SOLD
Fuel Hard Line to Carb - 10
Distributor w/cap wires & plugsSOLD
Crane Ignition (Fireball XR700) –
SOLD
Engine Mounts – 10
Valve Cover –
SOLD
Side Cover – SOLD
3sp Tranny and Transfer Case (no linkage, I may need it) – 200
Weber Carb –
SOLD
Brake booster with master cylinder – 80
Front Bench Seat (no rust, good padding but needs re-covering) – FREE
steering Box – 40
Steering Column – Pending
Front Axle Complete w/ Drums (Needs rebuild) –
DONATED TO LAND CRUISER JUNKY
Rear Axle Complete– DONATED TO LAND CRUISER JUNKY
E-brake assembly – 50
Free
Clutch Slave Cylinder
Clutch Master Cylinder
Hello,
I'm just wrapping up my motor right now since I had a motor with a crack camshaft. I could use that fuel pump and a back up slave cylinder since mine is a bit funky. I'm not sure if I'll find some hard lines for the fuel pump and I'm not interested in looking around so although the fuel line is cut to accommodate the weber I'll take that as well and slap that on my soon to be installed aisan carb. I'm hoping to start this lil piggie up sooner than later.
shipping will be to 92336
paypal ok ?
thanks
chris
to bad you didn't live closer cause I'd drive right over.
have a good one.
Just noticed I have a usable fuel line on the old motor so I'm in no need 4 the line now.
thanks
chris
ttt.
Lower prices. I move in a month and need to get this stuff out of the garage!!!!
Transfer case w/ tranny now 200
Starter 15
Alternator 10
Front bench seat Free if you pick it up
