1bbl. carb questions
high desert, ca
I have a few questions concerning a carb of mine. It is a single barrel D40, mfg. May 22, 1967, and without the solenoid. I am not that knowledgable of carbs, but am not afraid to take anything apart.
I am having a hard time finding the exact carb kit for this due to the large number of variations available during the production of this D40 carb. What keyster kit do I need?
My carb runs noticably different at 3000' than at 6000'. What is done to adjust for elevation? Most of my harder wheeling is done at higher elevations.
What is done to maximize performance when operating at an angle. Even at FSM specs for the float, I have a lot of flooding, much more than an aisin should. Suggestions?
Thanks, I assume the first question will propably be answered by mark.
when i re-build/cleaned my carb under a good shade tree i made my own gaskets because i could not find a kit that would work, luck for me my AP was fine and did not need replacing
i run the lean metering rod in my carb and it runs great above 3000ft and not the best at any thing under that, but that's a trade off that i live with.
I have never run in to any flooding with my sd40 even in moab where you see daylight for days. I do run out of fuel on steep decents but that like really steep shi* and then i just bump the clutch at the bottem or start her in gear.
