1999 Keyless Entry problen
Hello,
Brand new to the board. This is my second land cruiser. I previously had a 1997 that had no problems but a starter. I now have a 1999 Land cruiser with 115, 000 miles on it.
The problem is the Keyless entry unlocks the doors but does not unlock. If i lock the doors with the door switch and then press the lock button on the key the lights flash but the relay does not activate.
If the doors are all closed and unlocked, the lock button on the key does nothing, no relay activation, no light flash.
I am confused. The car was at the body shop for a passanger fender moulding replacement. When I got it back, the battery was obviously disconnected or dead because the radio stations were no longer programmed. Would that effect anything?
new battery in the keyless entry and the led glows when the buttons are pressed.
Looks like some good info on the forum! I hope someone can help.
Warren
Search in the sticky 100 series LC/LX FAQ. Same thing happened to me. Followed instructions and worked like a charm.
fixed
I tried all of he lock resets none would work. The problem was the passanger side locking mechanism that locks all of the doors. It was just a bad connection in the door. Thanks for the fast reply. I hope this info can help somone else.
Warren
