- Joined
- Dec 8, 2012
- Threads
- 1
- Messages
- 24
I am a US citizen currently back packing in Peru. I am considering purchase of a 1998 SWB 90 with the 1KZ turbo diesel to continue my trip. The truck has around 180,000 KM (108,000 mi) on the odo and appears in fair condition. Looking under the truck I can not find any oil leaks, checked the front and rear shafts from the transfer case for slack in the U Joints and spline sections. Everything seems pretty tight. Additionally from the inspection under the truck and the given lack of dings, dents and scrapes I am going to guess that this one has mostly seen highway use. There are no service records with this truck. I will know a bit more after the test drive later today.
Given the expertise I find here I wanted to ask what is a general figure to expect for diesel use-- either MPG or L/Km-- and are there any hidden gotchas that are not evident to look out for given the year and mileage? What kind of life, given reasonable care can one expect from the driveline and 1KZ powerplant? Doing a search here I found buying suggestions for other series LC's but did not find anything on the 90. I also think I recall reading somewhere that caution is needed when operating this power plant/ body combination at high speeds on hot days because of engine temps.This one is interesting because it has the cool down timer where after turning the key off, the powerplant continues to run for a couple of minutes. Additionally there are no locking hubs on the front wheels which I would assume if added, would increase mileage and lessen drive train wear.
Any help or suggestions would be appreciated.
Regards
Expat42451
Regards
Expat42451
