cruiserpatch
Supporting Vendor
- Joined
- Nov 24, 2020
- Threads
- 138
- Messages
- 1,369
- Location
- Atlanta, Georgia
- Website
- www.cruiserpatch.com
Figured I'd document this process since it's a bit detailed.
I know others have made videos about this (including myself) but the shift indicator bezel part is new-
I'll be adding details about that coming soon...
Tools needed:
I'm doing this with the mechanism removed from the vehicle but it is easy to do in the truck as well. Chock the wheels and shift into 'N' or 'L' to access the 2x screws on the reverse side of the shift knob. You'll want to remove the bezel covering this mess (attached to the cupholders). Unplug the seat heaters, 'ECT PWR' and '2ND START' buttons, and you're home free.
Shift assy. removed from truck
JIS screw removed from reverse of knob (blue loctite present. do not use a No. 2 Phillips. It will strip the head)
Locate the white connector with the 'O/D OFF' switch wiring (white)
Unclip the connector from the shift housing
(continued)
Tools needed:
- JIS screwdriver
- Flathead screwdriver or similar
- Depinning tool (very small pick or screwdriver will work)
- Sharpie/marker
(continued)
