1997 Transfer Case bench inspection
The Last Best Place
Searching mud it sounds like the transfer case is pretty bulletproof. As I was never able to drive my project and it has 301k on it, I'm wondering the best way to inspect it off the car. I've read the rear output shaft bearing can be problematic as well as the viscous coupler. Is there a way to inspect the VC off the car? Any other suggestions?
You can inspect the VC by doing the following, make sure center diff is unlocked:
First spin either the front or rear output flange. It should spin freely and easily.
Second hold either the front or rear drive flange so that it can't move. Next try to spin the opposite drive flange.
If you can trun the drive flange easily with minimal effort than the VC is not working and it's acting like an open diff.
If you can turn the drive flange but it's somewhat difficult than the VC is working.
If you can't spin the drive flange (i.e. both front and rear output shaft feel "locked" together) then the VC has seized.
I know this because I had a seized VC and wanted to make sure the replacement T case I bought had a functional VC.
Can't speak to the rest of the inspection. Also, you can lock the center diff to feel what a locked front and rear drive flange feel like.
How do you lock/unlock the center diff on the bench? It seems locked right now. Does it go in to locked mode when removed? Thanks!
In order to lock it you have to electrically operate the actuator. You can use the heater main relay as shown in the fsm screenshot below. The screenshot is for the front or rear diff lock but the center should work the same. I used a 6 volt lantern battery on the bench since there isn't much force to overcome.
If you want to lock it manually, then you have take the motor/actuator completely off (its 3 or 4 bolts, I can't remember) and there will be a plastic gear underneath. You can turn the gear manually and there are 2 distinct positions. One is locked the other is unlocked.
Good luck.
My favorite way to test the VC: Remove the retaining snap-ring, remove the VC, place both in the steel recycle bin, done, "problem" solved.:hillbilly:
I had Robbie Antonson in Boulder remove my viscous coupler and I swapped the rear nose of my transfer case for one he had rebuilt. The bearings in the rear nose of my old transfer case had become pretty loose. It was significant when we compared it to the rebuilt one. Robbie has rebuilt more of these transfer cases than anyone I know and he told me the viscous coupler isn't mandatory and it won't hurt the vehicle to remove it. I like to control when my diffs (including the center diff) lock up and removing the viscous coupler gives me that control. The only purpose it really serves is to act like a traction control mechanism and lock the center diff when you lose traction. When your VC becomes old, it can present some problems so removing it seems like a sane action to take while you have it off the vehicle.
