1997 power antenna specifics
Seattle, Washington
I know there are supposed to be post regarding R n R of power antenna mast units, but i dont feel like sifting through old broken links.
so my specific question is where the heck does the power antenna coax disconnect?! aside from the back of the radio, is there a quick disconnect ( not cutting with knife) somewhere between the radio and the mast input? i cant even get it out of the fender. i nearly took my glove box/jockey box out and im faced with electronic modu. and quick disconnect plugs.
am i even in the correct area or is the only way to take the antenta mast out if take my dash apart and radio out?
TIA
Back of the radio. Mr toyota screws up again...
cheers,
george.
If you don't use search you may be SOL. But to answer your question, NO there is no disconnect other than the back of the radio. But I wouldn't go about it through the dash, cause fishing the cable is a PIA. There is a way to work on the antenna mast and motor through the fender, a search should turn up the link.
If you do pull the coax and antenna assembly, be sure to attach a fish line so that you can pull it back through the 90 degree entry from the inside back top fender thru to the dash. Unless you really were looking forward to taking the fender off to accomplish that if you forget the fish line.:(:slap:
OK, it may not be that bad, but people have reported doing that for a (extreme) solution.
