1997 keeps blowing same fuse
Here lately, my 1997 80 has developed a habit of blowing the fuse powering the windows, sunroof, heater/ac fan, and bottom dash lights for lockers, cdl, abs, etc. It's one fuse that continues to blow. Have any of you guys seen this before? Thanks!
God that sucks. Had the same problem in 110* heat. Mine would blow every once in awhile last week and then would continuously do it. The worst part is it did it on a 400 mile trip from home and I lost the over drive with it.
Since I lost climate control I thought I had pinched a wire on stereo install and that the rough roads I had been traveling on chaffed the wire.No go
Turned out one of the sensors on the tranny had vibrated loose and was causing the fuse to blow ( passenger looked it up on the Internet once we got service and fixed it on the side of the road outside Mojave) If you search there is a several topics. One person traced it out and found out that fuse had 60+ circuits on it. Including reverse lights, a/c trigger,ect.
By the way, the reason i narrowed it down to the VSS sensor was the Ultra gauge popped a code with P0500. I got lucky it finally popped a code up after going through 6 fuses.
The gauge fuse? If so, check the engine wire harness where it goes by the EGR pipe.
Bumping this since I'm having a similar problem. My gauge fuse will blow after the truck runs with the a/c on for a few minutes. It seems to be an over draw, and not a short to ground since the fuse will heat up and then blow. If the blower motor is off it seems to be fine. I am having internet issues so I have not looked at the wiring diagram yet to see what that fuse powers up.
Seen this problem here before.
I believe it was the A/C clutch causing the short.
I replaced the a/c compressor with a new Denso from Amazon, which was only $190, and so far no problems. I also relpaced the drier with a new Denso from Amazon as well but it is from a 2004 Tundra and about an inch shorter.
Just ran into the same issue as you described. Thanks for your post. Took it to McIntosh Imports in Mount Pleasant, SC. Terry took a look and it is looking like the root of the problem is the AC clutch is drawing too much and shorting the 15A fuse. I'm going to do a full clutch+compressor replacement. FYI found both on Amazon Prime for a good deal. Denso Compressor Part # 4711166 & Denso Drier Part # 4780503. The total ticket came out to $213.
