1997 brake rotors
Squamish
hey guys i am wondering ar ethe front rotors bolt on or slide on ..and are the rears bolt on or slide on?
The front rotors are bolted to the hub, so there is a fair amount of work to replace them. See the Birfield repack writeup in the FAQ.
The rear rotors are simple, just remove the calipers and the rotors slide over the wheel studs.
so does that mean once you have unbolted the rear rotors they are just the rotor...with no hub or anything ...im jsut wondering cause then the shop can machine my rear rotors
Yep - once you remove the caliper you slide the rotor off and then you can have it machined (lots of threads about machining rotors if you search). The rotor can be a little stubborn to get off because there is a "drum in disc" emergency brake pad that rides inside the rotor. There is an adjustable star wheel that you can rotate with a brake tool or screwdriver to release the tension on the emergency brake. FSM would be of value if you aren't familiar with brakes.
You do not need even unbolt it. Take off rear wheel and remove brake caliper (2 17mm bolts behind). If your parking brake loose, then rotor should just slide off. If it does not DO NOT screw bolts into threaded holes, but rather rotate rotor in such way that rubber cover will point down, remove rubber cover and using small torch locate adjusting crown inside. Then using long flat screwdriver rotate it downwards 4-5 clicks and rotor should easy came off.
If I had known this years back, I would have NOT learned by experience..:whoops:
Good advice here on MUD (as usual)..;)
Gday
Here are the rear disks.
See the adjusting hole?, and the jacking bolt holes, between the wheel stud holes - put it at the bottom, slightly to the front to find the adjuster. The adjusting hole may have a rubber plug in it.
Hope this helps.
Matt
