Parting Out 1996 Toyota Land Cruiser FJZ80 FJ80 LX450 maroon color - Decatur, GA
Atlanta GA
This is a list of parts I have left from partout. If not on the list, I do not have.
Pricing is definitely negotiable . Will ship. Just make me an offer.
Finally disassembled my doors and rear hatch. No interior panels.
$20 each Door glass windows and quarter (has tint)
$5 each Door glass run channel
$15 each Door weatherstripping (plastic clips still attached)
$35 each Power latch lock actuator assemply
$35 each Power window Actuator (front pass sold)
$20 each Exterior door handles maroon
$15 each Interior door handles tan brown
$5 each set Door hinges
$15 each Door wiring harness
$25 Door control ecu 85980-60110
$40 Rear hatch window wiper actuator . Control mod . wiper
$20 Hood - maroon (some rust)
$60 Sunroof assemby
$20 Dash and rear vent ducts AC
$50 each shell only Doors (some rust)
$20 Carpet
$20 Cooling fan & clutch
$15 ABS skid computer 89540-60040
$60 each Air bag assembly and cover
$15 Gas door release cable
$15 Exhaust manifold covers 11212-66011
$15 Motor and trans mounts
$175 Dash wiring harness 82131-6A432
$13 Roof control 85921-60011
$145 Harmonic balancer damper w/ bolt
$12 Headlamp retainer 85961-300526
$12 Seatbelt warning module 85991-16050
$90 Fuse wiring harness
$12 Bumper lower grill 53112-60030
$75 Floor wire 82161-60033
$60 AC evaporator assembly 445800-0930
$10 Relay denso 90987-02004
$55 Sunroof motor 85730-60011
$10 Flasher 81980-12070
$10 Relay 056700-4750
$50 Floor wire 82162-60052
$10 Heater amp module 87161-60020
$10 Fuel tank filler neck shield boot
$50 Actuator assembly brake - for parts only 44510-60010
$30 Fuel pump relay 28381-16020
$10 ABS relay skid control 88263-12080
$30 Igniter 89621-26010
$10 motor mounts
$30 Cruise control 88240-60060
$30 Floor wire 82181-60043
$30 Gas pedal assembly and cable
$10 Hub kit
$20 Transmission relay 89531-60010
$10 rear heat control
$20 Lamp control 85965-60010
$10 Rear defrost control
$10 relay denso 90987-01003
$10 Radio antenna control
$5 door sensors
$5 Relay denso 90987-04002
$5 relay denso 90987-02006
$5 Lower water neck
$5 RH passenger rear bumber mount
$5 Door latch hardware
$5 front hub-dust seal
$5 Cam shaft seal
$5 engine rear oil seal
$5 Gasket differential 42181-60060
$5 passenger door lock switch
$5 power outlet trim
Do you have a drivers side beige visor in good condition?
Do you have a center diff lock switch?
95476
Thanks!
On the wiring harnesses you have listed - I’m looking for the non-US heated seat connectors that are in the US spec trucks under the center console. I need the wiring from the center console to each front seat including the connectors on each end. Not sure of part number. Thanks.
Interested in the carpet if it's Oak color and the driver seat (if not torn up and you want to bust them up, could be interested in front pair) Could the passenger seat bottom swap for the drivers bottom?
29907 SC
Do you have the trim piece at the base of the door windows? Mine the black rubber is breaking off and the chrome is showing through.
In need of Oak(brown) color Dash a.k.a. 'crash pad' :
Is it available? text @ 512-8o8-9001
OEM part number : 5540160150e0
Lock Set with or with out security box?
