For Sale 1996 RHD HDJ80 Manual Shift Console and Clutch Pedal Assembly
Stuck between a rock and a hard place
These would be of interest to RHD HDJ80 or 81 owners who are converting from auto to manual.
Both out of a 1996 UK-Spec RHD HDJ80. I can't use either as the truck I am converting is LHD.
SOLD RHD Shift Console is the blue-grey color, has a few minor scratches, but no cracks or major damage. Shift boot has no tears. $130 US for both + shipping. Part numbers 58811-60110-B0 and 58808-60070-C0
full
RHD Clutch Pedal Assembly. All bits and pieces are there and working. There is minor surface rust on the box, and the rubber pad needs replacing, but nothing broken. $90 US + shipping...beats having to assemble the bits and pieces.
full
PM if interested.
Hey Cyclo,
I'm VERY interested in the console box - I don't need the pedal assy but will buy the box at your nominated price. I'll send you a PM with my details from Australia.
Cheers !
PM sent- or conversation started as I couldn't get PM to work, hope to hear from you soon Steve.
Here's my mini console Steve, so I have the front bracket Yaay.
If you have or can help with the rear spacer 58875 in grey (?) (58875 SPACER, CONSOLE BOX 58875-60010-B0BLUISH GRAY, TRIM1*) and not sure what the 58919B is : 58919BPLATE, CONSOLE BOX 58919-60010-B0BLUISH GRAY, TRIM1*, as that's not on my mini console for sure.
Any idea what these are : 58871CUSHION, CONSOLE BOX, all from the pic below.
58871-60020
Cheers,
Alex.
But it looks like the autos sold in Australia have the same spacers and cushions - ad consoles for these are a dime a dozen so I'll head off to the salvage yard mate !
Just looked at the salvage yard and compared to your pic - the console you're selling has the 'spacer' still on it so I've got the bracket of my mini console and the spacer under control. What I don't know is what's the 58919B
Is this on the console you have as I can't see in the pic if it's there.
I've also asked the wreckers if they will cut the floor out of the car that HAD a console so I can carefully grind off the mount that's welded to the floor just in front of the centre console where the "S" is shown below. Hope they will oblige !
BR,
Alex.
The 5mm x 5mm by 10mm rubber spacer is indeed still on the console. As you noted, the issue is with the brackets for the rear. If it is like the LHD center console, one bracket is behind the arm rest, but the other will need to be added/welded.
EDIT Try these PN 58993-60010 and -60011. I think those are the rear one, they would be bolt on.
I'll just have to hope the wrecker will cut that rear floor bracket out for me I guess. No mind, I'll figure something out and if they won't do it I'll ask if I can do it as the shell is heading for the crusher anyway - she took a big hit up the rear ! I'll get it somehow and glue/screw it to my floorpan.
Is this 58919B the spacer you refer to "5mm x 5mm by 10mm rubber spacer is indeed still on the console"
If it is then all I have to do is get that rear mount at the salvage yard and I'm good !
Thanks for all your time on this.
Hi Steve any news please? Still hoping I can get this chunk o plastic into my truck somehow. I've got the rear floor bracket now (and a section of floor!) from the salvage yard. Cheers
