Trade 1996 LX450 Stunning
Zionsville, IN
96 LX450 Info and Pics ~$12K
None locker
182K
EGR code and a little oil leak out of the rear main seal are the only issues to mention.
Has really nice seat covers very clean inside
4/1/1996 10 P.D.S.
4/1/1996 10 FULL TANK OF GAS
4/15/1996 17 INSTALL TOW HITCH
4/15/1996 17 INSTALL GOLD KIT
4/22/1996 125 INSTALL RUNNING BOARDS INT #200390 ---COMPLETED
4/23/1996 126 INSTALL ROOF RACK INT #200394
6/19/1996 2157 1000 MILE SERVICE
6/19/1996 2157 INSPECT AND CORRECT FLUID LEVELS
12/5/1997 18327 --REPLACED MISSING CENTER CAP.
12/5/1997 18327 AIR BAG LITE ON CLIENT STATES --C
4/9/1999 32987 STATE INSPECT/I-M TEST
4/9/1999 32987 CERTIFIED PRE-OWNED PDI
4/9/1999 32987 OIL SERVICE FOR MILEAGE ON CAR
4/9/1999 32987 REPLACE ENGINE OIL WITH PREMIUM V
4/9/1999 32987 REPLACE AIR FILTER
4/9/1999 32987 INSPECT STEERING GEAR BOX FOR OIL LEAKAGE
4/9/1999 32987 INSPECT BRAKE PADS AND ROTORS FRO
4/9/1999 32987 COMPLETE DETAIL SPECIAL
4/9/1999 32987 REPLACE FRONT AND REAR BRAKES
4/9/1999 32987 FOUR WHEEL ALIGNMENT-SPECIAL
4/9/1999 32987 ROTATE & BALANCE TIRES-SPECIAL
4/9/1999 32987 HEADLIGHT UNIT (ONE SIDE) R&R
4/14/1999 32989 TOUCH-UP
11/9/2000 60157 ANTENNA MAST IS BENT REPLACE PER CUST AUTH
11/9/2000 60157 CHECK ENGINE LIGHT IS ON CUST STA
11/9/2000 60157 BRAKE LIGHT COMES ON AND OFF INTE
12/28/2001 82202 BATTERY R&R
12/28/2001 82202 STARTER ASSEMBLY R&R
4/9/1999 32,987 Replaced front and rear brake rotors/pads
12/28/2001 82,202 Replaced starter assembly
1/1/2010 - New O2 sensors
10/1/2010 - Front axle rebuild (bearings, seals, grease), front/rear diff fluid change
11/1/2010 - PHH
12/1/2010 - Tranny fluid change, coolant flush
3/1/2011 - New PCV hoses, valve cover seal, spark plug seals, oil pump seal
9/10/2011 159,300 Oil+filter change
9/19/2011 159,500 New wheels/tires
10/8/2011 160,200 New windshield and OEM seal
10/9/2011 160,200 New Bilstein 4600 shocks, OME stock height coil springs
11/12/2011 161,150 New belts, OME steering stabilizer
2/5/2012 163,040 Valve cover gasket, PCV, PCV grommet, throttle body gasket, VSV for EGR, spark plugs,dizzy o-ring
spark plug tube seals, heat tape around harness, various vacuum lines,
2/18/2012 163,320 EGR vacuum modulator
2/21/2012 163,350 Set timing at 6°BTDC (was previously at 0°, spec is 3°BTDC)
3/31/2012 164,300 New battery, oil+filter change
4/25/2012 164,750 New spare tire
5/8/2012 165,245 Greased knuckles
5/9/2012 165,395 New blue hub fan clutch
5/14/2012 165,750 Greased u-joints, slip yokes
5/15/2012 165,780 Front/rear diff fluid change (Mobil 1 synthetic 75W-90)
5/17/2012 165,795 Transfer case fluid change (Mobil 1 synthetic 75W-90), relocated diff breathers
8/2/2012 168,250 Tire rotation (5 tire rotation pattern)
8/18/2012 168,450 Reset bearing preload (20 ft-lbs)
9/7/2012 168,800 Greased knuckles
9/22/2012 169,415 Replaced ignition wires, distributor cap, rotor, set timing at 3°BTDC, oil+filter change
2/16/13 172,262 Rotella T6 oil and Toyota filter
8/16/13 179,000 new ceramic pads and rotors all around.
10/15/13 180,000 Rotella T6 oil and filter.
10/15/13 180,000 Trans Fluid drain and fill
9/16/2011 New badges
UltraGauge
Tires/wheels/mount/balance/lug nuts
Floor mats/cargo liner/vent visors
Front seat covers
9/22/2011 Front bumper + repaint
10/8/2011 New windshield+OEM seal
10/9/2011 New Bilstein 4600 shocks, OME stock height coil springs + steering stabilizer
10/25/2011 Steering shaft dust seal
Parking light lens
Side marker light grommet
11/1/2011 Rear seat covers
Land Rover cup holder
11/12/2011 Belts (3)
11/25/2011 Mirror bolt cover
11/27/2011 Scion T1806 head unit
1/15/2012 Dash lights
1/18/2012 HID headlights
LED interior lights (domes, map, doors, license plates)
1/28/2012 Hatch light fixture/LED panel
2/4/2012 VSV, spark plugs, tube seals, dizzy o-ring, valve cover gasket, PCV
2/8/2012 LED tail lights, clear corners/blinkers
2/18/2012 EGR vacuum modulator
LC console swap
Corner/blinker wiring
3/31/2012 Backup LEDs
Depo headlight housings and bulbs
LC grille
Battery
4/25/2012 New spare tire
5/9/2012 Blue hub fan clutch
5/15/2012 Front and rear diff oil exchange, diff plug gaskets
5/17/2012 Transfer case oil exchange
Relocated diff breathers
8/3/2012 Wheel
Wheel refinish
Spare tire mount and balance
8/20/2012 Axle flange studs/nuts/cone washers
9/22/2012 Ignition wires/distributor cap/rotor
11/1/2012 Front mud flaps
12/1/2012 Wheel center caps
http://www.flickr.com/photos/benschmittphoto/8384381481/in/set-72157632529985767
http://www.flickr.com/photos/benschmittphoto/sets/72157632542584848/
Clean and Clear title in hand
What do you have for trade? Probably looking for a Regular cab tundra V8 4x4
I'm 6'5" and the LC just aren't working for me anymore and there is absolutly NO off roading around here.
