1996 Gas Filter Technical ?
Hello to all-
My 96 Cruiser has the 1FE V6 Engine. I am in design process of relocating the gas filter from its current location "under intake air plenum" to area on the drivers side fender inside the hood " off-course....lol". For easier access , to replace when needed. Long story short,,, my 80 sits a while at time and is stored for the winter months,, so i replace my filter every 2 years. Yeah, I know some of you feel it takes many years before replacement is required, but after seeing what todays fuel turns into "furniture varnish smell and becomes heavy / changes color , sediments, etc,,, you get my point" after sitting for more than 2 or 3 months in minus 20 degree or lower weather. "Garage not heated",,,,, you would understand better.
My technical question is ,,,,,,,does it matter that I am mounting the gas fuel filter still in a horizontal position, but simply flipped around so the mounting tabs bolt holes are facing downward? I personally say no, but I wanted to check in with the rest of the cruiser community
I already made a custom bracket to house the gas filter and clear the banjo bolts properly. I also had a press shop make me a rubber line rated for fuel delivery and EFI pressures, with the banjo fittings from the fuel to the new gas filter location. All my life working on gas engines the fuel filter was replaced either at a particular reason or at a specified service interval. Their factory location is just not for me. Maybe it is not a needed mod, but works for my needs.
I am going to assume that those of you who have cut the filter in half for inspection , the entire radius of the filter element or media is a full circumference of the fuel filter. Also I never had a quality gas filter leak, if new crush washers and banjo bolts are torqued correctly, all is good to go.
Thanks:cheers:
CRUISER MONKEY
For the record, it's not a V6. It's a straight 6.
Curious to see what you come up with. Photoman has made something like what you are thinking about.
How did it turnout? I'm in the process of doing the same. Since I did away with the EGR systems and charcoal canister I'm planning to mount it to the factory charcoal canister bracket that also has my front diff breather.
You could also look at the Land cruiser 100 series. There's are located to the drivers fender. Very easy to get to. Maybe a 10 min swap.
