1996 Fjz80
El Dorado National Forest
Before the long trip home, U-joints greased. New drivelines 10,000 miles ago.
In Reverse it Forward there is this squeak after the truck warmed up. I think I know what it is, need confirmation. Also noticed u-joint looks seated funny in the front yolk of the rear dL.
In for hearing about what you find. I have a similar low speed squeak in my white cruiser. Embarrassing at times ... the repairs never end.
Definitely U-Joint sounds, as I can hear it echoing through the DS.
Those caps are not the right size for the yoke.
Assuming it is an actual Toyota DS, then source new, correct U-Joints from Kurt at Cruiser Outfitters. Matsuba are the current best replacement.
Do you have the history on the DS?
How do your brake pads feel?
Any chance you’re on the last leg of the pads?
-Any idea the last time pads/rotors were done?
Also, what if you fiddle “intensively” with your e-brake & try to isolate out that it’s not those inner drum pads?
That way worst case scenario is you pull wheels to check rotors, but won’t need to pull the rear rotors just to do a visual on the drum/e-brake pads.
I think I’m hearing brakes on my phone......you tell me.
As for the drivelines, I’d want to see my old grease flush & my new just start to creep out the joints - those look dry IMO.
But I grease the crap outta everything. Everything.
It’s like free rustproofing to me.
Sometimes the grease fittings plug up.
So here’s the skinny. U-Joints @ rear ds both bad. Front ds U-Joint going bad. Both DS rebuilt 13,000 miles ago. This was due to improper installation of rear DS, it was out phase instead of in phase :(. All getting corrected now. YAY.
The improper installation of the DS was causing the grinding noises when turning right. This eventually got worse and worse to the point where the squeak of the U-Joints were on the last straw of failure. 3,500 mostly highway miles was put on the LC with these failing components.
The bummer is I took the LC to 3 different Toyota dealerships to get corrected and all told me nothing was wrong and sent me on my way. :(. With all y’alls help with diagnosing we figured out the problem. I hope it is only the U-Joints and don’t effect the rest of the drivetrain. This is one of those rare LCs that was, hopefully still is, in immaculate condition with minor wear, and still with Toyota original parts. 🤞
You are spot on with the echo noise, that noise three me for the same sounds as the brake baking plates. 💯
Now that DS is fixed, you are correct, good ears. Totally heard brakes as well. Rear to be exact.
