1996 4 Runner fluids
My 4 Runner is sitting at 150,000 miles. The truck has been great over the last 9 years that I've had it. My question is about maintenance for a somewhat of a high mileage vehicle (we no toyotas can go for much longer though :) ) I have no problems at all at the moment but was wondering if I should replace all fluids? I'm not very mechanically minded and even if I was...I don't seem to have the time to do it myself. So, what fluids (please list them) would you consider replacing? Anything else I should consider as well.
Of course, I'm sure that you know...oil and antifreeze.
Then there are front and rear diffs and transfer case - all take 90wt gear oil. I prefer Redline Shockproof.
Also the transmission. If you have a manual, its also 90wt gear oil.
If its an auto, then it uses type-iv ATF. If you're not really mechanically inclined then let a shop do this. Have them take off the pan, replace the filter and drain/refill. DO NOT have them do a power flush. I've heard too many horror stories of people having power flushes done on higher milage transmissions, only to have them fail shortly after. When they do a power flush, it basically flushes all of the gunk that's built up on the filter back into the transmission. It will also blow seals if they are already starting to get worn or brittle.
Other than that, grease the ujoints on the driveshafts, and thats about it.
my compliments to all you guys on changing fluids!
Perhaps a personal preference/pet peeve but I think a regular changing of fluids is the cheapest and best return on maintenance $ that you will spend. Keep a well sealed clean air filter and X2 on coolant before it starts wrecking your rad and heater core.:cheers:
