For Sale 1995 Toyota 4runner crawler SAS Clean Lockers Crawler gears 4.7 Daily Driver SR5 A/C
Arroyo Grande, CA
Sold!!!!
I've only put 2,000 miles in almost a year and a half. The entire build including tires has less than 7,000 miles. And it's only seen dirt a few times. I am selling to buy and build up an FZJ80, (so possible trades considered or for 4 door Tacoma).
Vehicle;
1995 4runner SR5 original white and pin striping, PW, PL, PM, Air conditioner blows cold, rear heater, everything works, clean title, clean carfax, (not a salvaged vehicle!), with 3.0 liter V6 with R150 5 speed transmission with V6 adapter plate to gear driven 23 spline T case with 4.7 lowered gears. It has a Toyota 1985 solid axle with 5.29's and Detroit lockers in front and rear axles. TG front bumper with M8000 winch in front brand new, with new style Marlin rear bumper and rock sliders. Viar OBA. Clean inside and out. Even the undercarriage is very clean, with no visible rust. The interior is very clean except for a tear in the drivers seat. The body is the original paint with no sign of accidents. There is 207k miles on odometer. I have "Plasti-Dip'd" the chrome on mirrors, grill, (which was removed prior to), rear license frame, and Centerline wheels. This can be simply be peeled off if you don't like it. The only prep work for the Plasti-Dip was degreasing, so no damage from sanding was done.
Here's the history of last two owners, all this jives with Carfax;
12/10/2009 - 9/15/2010 - This owner did the build of this vehicle over the course of approximately 9 months. In addition to all the mods he did, he also put a 91 rebuilt motor, (with new timing belt, water pump and tensioner were replaced too).
9/15/2010 - 5/27/2011 - This is who I bought it from in Visalia. He bought it and used it to commute to work mostly and put about 5,000 miles on it, and sold it because he was going through a divorce. This owner also had a new clutch, Odyssey battery, and Viar OBA system installed, and had the allpro crossmember driveline brake finished.
I have owned it since 5/2011 and put about 2,000 miles since, and I've taken it to Bald Mountain twice in the last year and a half. Winch has never been used! When I did the most recent tune up in June 2012 cylinder compression was 175-190 in all 6 cylinders. Motor runs strong for a 3.0L. It doesn't burn or leak any fluids.
Engine, Transmission and transfer case;
Stock 3.0L with K&N cold air intake, (PO gave me stock airbox), R150 Transmission to Marlin V6 adapter plate mated to 1985 top shift transfer case with a set of trail gear 23 spline 4.7 lowered tcase gears.
Front Suspension;
TG IFS eliminator 4" lift kit with Bilstein 5150 upgraded shocks; (Front Leaf Springs, High Steer Crossover Steering Kit, Front Drop Hanger with Greasable Bolts, Greasable 5" Shackles, Frame Tubes & Jigs, Steering Stabilizer Kit, U bolt Flip Kit, Shock Hoops (2), Bilstein Shocks (2), Front Brake Lines (2), Vented Rotors (2) Bumpstop Extensions (2), Wheel Spacers (2), Bumpstops (2), Front Axle Gusset, Axle Diff Armor, Knuckle Service Kit, Wheel Bearing Kit (2), Motor Mount Cover Plates, Spring Pad).
Plus 1985 Front axle. Trail Gear "assembled 3rd member" - (complete 3rd member with 5.29 Ring and pinion gears, and Detroit Locker). Longfield ringed birfields, and weld on diff armor and upper gusset. Long spline front drive line assembled with an 85 front shaft. Front axle rebuilt 6 months ago.
Rear suspension;
1995 rear axle. TG classic rear 4 inch lift kit, coil eliminator kit with Bilstein 5150 upgraded shocks; ( 56" Long Rear Leaf Springs, Welded Rear Spring Hangers, Rear Shackle Mounts, Greasable Rear 5" Shackles, 12" Bilstein Shocks, Shock Mounts, U-Bolt Flip Kit, Extended Brake Line, Spring Perches, Greasable Spring Bolts & Bushings).
Plus TG "assembled 3rd member" - (complete V6 3rd with 5.29 R&P gear ratio, and Detroit Locker). Weld-on diff armor.
Steering;
IFS steering box, high crossover steering done correctly so you have full travel, drag link and tie rod do not hit!
Armor;
Marlincrawler new style 4runner rear bumper with full side frame contact points
Rock Sliders welded to frame with gusset supports
TG Front bumper w/o hoop
Warn M8000 winch, brand new.
Allpro Offroads X-Member crossmember with driveline disc brake installed, (primed for rear disc conversion!).
Tires and Wheels;
315 75 R16 BFG KM2 Mud Tires on Centerline rims (Plasti-'d black). Tires have less than 7,000 miles on them.
Viar on board air system
Pioneer CD / DVD Navigation stereo
This truck has been great to me so far. Drives straight down the road, (sways a bit in the turns with no anti-sway bar :-), and pulls great on the highway. Since I've owned it I've changed engine oil changed in June 2011 @ 205,300 miles and May 2012 @ 207,134 miles with 10/30 mobil 1 synthetic. All 4 boxes topped off with GL-5. Recent tune up, NGK BKR5EYA plugs, Denso wires, rotor and cap. Front axle rebuilt using Marlin kit 2/2011 to factory specs. New front brake pads @ 205k miles. New radiator core @ 207,155 miles. Clean carfax from when I bought it in hand. Two sets of Keys and Fobs. Also as said above; I have "Plasti-Dip'd" the chrome on mirrors, grill, (which was removed prior to), rear license frame, and Centerline wheels. This can be simply be peeled off if you don't like it. The only prep work for the Plasti-Dip was degreasing, so no damage from sanding was done.
Asking $9200 OBO. Truck is in Fresno, CA. I am willing to trade either for an FZJ80, or 4 door tacoma.
Email me at jeffmackey1 at hotmail.com
Key words - rockcrawler rock marlin tg trail, A/C AC conditioning, nav
