1994 LC check engine light ?
Kailua Hawaii
I posted in this question in the wrong forum, Hope this is the correct one.
I have a 1994 LC and have been getting a CEL of and on for some time. I replaced the 02 Sensors a while back and the problem went away, (for a while)
I had to smog it and I disconnected the battery to reset the CEL, worked just fine to turn it off, I drove it on the freeway and then went to have it smoged, Passed.
On the way home I had it washed and the CEL came on again. first code 26, then I reset it again and got a code 21.
Since I had already replaced the 02 Sensors not long ago I wasn't sure what to think.
I undid the 02 Sensor plug and found water. blew it out and still got the 21 code. I replaced the Sensor with the old sensor I took out and code went away.
Has anybody else had the problem of water getting into the plug of the 02 sensor?
How do I or did you stop this from happening?
Now that I think back its happened alot when I have had it washed.
Is this a known proplem?
Thanks for the help.
There is a simpler way to turn off the CEL.
I believe it is the EFI fuse - a 15 AMPer under the hood.
Pull the fuse for 10 seconds w/ the ignition off , and VOILA ! :D
( Gotta love OBD I for some things :cheers: )
I had a code 28, and 71 , prior to replacing my O2's.
Used OEM sensors, and now I get a code 71 roughly every 2nd or 3rd fill up *for a brief bit* and it goes off on its own.
I suspect this is the older equivalent of the infamous P0401. :doh:
At any rate - your connectors - interesting. I wonder if dielectric grease would help, or perhaps a little silicone applied around the outside seam prior to plugging the harness back into its hole in the body.
I also wonder if the truck side of the connector is damaged somehow.
Assuming, or course, that you used OEM sensors - ? :confused:
Britt
Thanks for the reply, Yes I used Toyota sensors I bought from Cdan.
I checked and it was 1 year ago I changed the sensors. But the reason for the change was the same, CEL. I need to find out if the products will work without enter fearing with the correct function of the sensors
But like I said I remember the rough idling and CEL after going through the car wash..
