Hey everyone,
I am chasing a stubborn electrical issue on my 1994 JDM Toyota Land Cruiser Prado (Wide Body, 1KZ-TE Diesel, Chassis: KZJ78-0024463). And I leave on my trip next Friday the 26th. Uhhhg!
Vehicle Setup and Context:
The Oil, T-Belt, and Alternator/Charge lights all illuminate simultaneously when the engine is running. (Currently, after some work around testing, only the Oil light remains on, but the charging failure persists).
The alternator is an aftermarket 140a and has had zero issues and is only 3 months old and it would be too much of a coincidence for it to go bad right at this moment just sitting in my driveway while installing a stereo. Batteries read a healthy 12.59VDC at rest, but with the engine running, voltage stays stuck at around 12.25VDC and drops into the 11V range under load (headlights, wipers, blower fan). It is running entirely off battery reserve.
The interior 7.5A CHARGE fuse reads 0V (technically a 0.737VDC ghost voltage) when the ignition is switched to the RUN position. The 15A ENGINE fuse gets a perfect 12VDC.
Multi-Meter Testing Done (Using a Fluke 15b+):
I have completely removed the temporary bypass and re-spliced the factory Thick Yellow wire back to itself on the White cluster plug. The truck is back to a 100% factory layout. Because of this, the dashboard warning lights are fully lit up again just like they were when the problem first started, and the alternator is still failing to charge. Note that the circuit diagrams I have access to might not be 100% specific to this exact KZJ78 layout, but they are the only ones available.
Where I Need Help:
Firstly, anyone ever had this problem and what was the resolution? The factory wiring between the healthy ignition switch (outputting 12V on IG2) and the dashboard harness (reading 0.73V on the thick yellow wire) has a massive bottleneck or high-resistance dropout that possibly occurred when the cluster loom was slightly shifted.
Because I don't see any obvious external plug-in ignition relays containing a yellow wire on the under-dash bracket, I need to know:
- Engine: 1KZ-TE Diesel.
- Recent Modifications: Updated the stereo stack to an Alpine iLX-507 and pulled out an old Japanese Carrozzeria center speaker/processor. Kept the existing sub, crossovers, and rear pods.
- The issues started right after I traced and removed all the old aftermarket wiring and cleanly installed the new Alpine. I was about to start putting everything dash related back together and when I started the Land Crusier to keep the battery charged since the doors were open all day while I tested the Alpine features to make sure it worked correctly. I noticed that the timing belt, oil light, and alternator lights were on. The only thing that I could think of being an issue at the time was that when I was disassembling the dash components, I moved the instrument cluster forward about an inch to see how hard it would be to replace the mechanical speedometer cable. I encountered resistance, immediately stopped, and put it back. No wires were forcefully yanked, jerked, or broken as I was very careful to identify only aftermarket installed radio wiring. I am an experienced installer of anything that a police car has in it, equipment, lights, radios, camera systems, etc., and I also used to work for Motorola a couple of decades ago as an installer tech. So I can unequivocally say that I was extremely careful about what was pulled on and cut out.
- Fusible Links: Removed, physically inspected, wire brushed, treated with DeoxIT, and reassembled under the block cover. They are taut, solid, and completely intact.
- Cluster Printed Circuit Board: Fully traced for continuity from each of the pin sockets out across the green film paths. All traces show perfect continuity.
- Brown Plug: Pin 11 (Solid Red, Alternator L wire) shows a constant 12VDC (back-feeding from the engine bay). Pin 1 (Yellow/Black) reads 0V.
- White Plug: Pin 5 (Thick Solid Yellow wire) is the primary ignition feed line, but it reads dead at 0.730VDC.
- Ignition Switch Verification: Directly back-probed the mechanical key cylinder block. AM1, AM2, ACC, and IG2 (Brown/White wire) all show a solid, clean 12VDC with the key in RUN. The switch is outputting power perfectly.
- Starter Relay: Tested Denso relay 28300-54110 on the inner fender block. Heavy terminal has constant 12V, coil trigger has 12V in START, ground is solid, and coil reads exactly 81 Ohms. Relay is 100% operational.
- Alternator Case Ground: Ran a voltage drop test between the negative battery terminal and the raw aluminum alternator housing with the engine idling. It reads 0.004VDC (a perfect ground). Hooking up heavy jumper cables from the battery negative directly to the alternator casing made zero difference in charging output.
- Alternator Harness Plug (Unplugged, Key in RUN): All three pins (S, IG, and L) show a full 12VDC on the harness side when disconnected from the alternator casing.
- The Dash Bypass: I cut the factory Thick Yellow wire (Pin 5) on the White plug at the back of the instrument cluster, isolated the vehicle/harness side, and ran a temporary 14-gauge 5a fused jumper line from the load side of the 15A ENGINE fuse straight into the cluster-side of Pin 5. This immediately sent a clean 12VDC down to the 7.5A CHARGE fuse and successfully extinguished the charging/T-Belt lights and oil light.
- The Charging Standoff: Even with the dash bypass active, the alternator still outputs exactly 12.25VDC at the main B+ lug and battery terminals.
Where I Need Help:
- Where does the Brown/White (IG2) wire from the steering column switch transition into the Thick Yellow wire that splits to feed the dashboard cluster and the engine-bay alternator plug?
- Are there any hidden factory tape-splices, internal junction block bus-bars, or intermediate connectors buried behind the dashboard panel structure that are known to fail or back out on these 70-series trucks when the loom is flexed?
