1994 cruise switch-- how does it work??
Yukon, OK
My wiring and schematic reading skills are lacking.. My basic question is: how does the toyota cruise control module know what button (resume, set, coast, cancel) has been pushed? I am trying to determine if it's possible to modify the stock cruise switch to work with a chevy DBC cruise module on my swap. Or if I'd be better off just using separate switches-- though my preference would be to use the toyota. Most of the schematics I see on the Chevy side need 4 wires from the switch. Toyota has 3, so I'm fishing for a workaround. I'm fairly committed to using the chevy module at this point, so I need to figure out the wiring for the switch rather than keeping the toyota cruise module-- which I've seen others do. Below is a partial of the toyota setup. Any help is appreciated
I am working on the same problem, but for a dbw setup. The way the switch works is to vary the resistance/voltage for each state.
CCS ↔ GND (C18−18 ↔ C18−13)
B−G ↔ BR
Ignition switch ON 10 − 16 V Ignition switch
ON CANCEL switch hold ON 5.1 − 8.3 V Ignition switch
ON SET/COAST switch hold ON 2.4 − 4.0 V Ignition switch
ON RES/ACC switch hold ON 0.8 − 1.4 V
I believe you would need some type of ADC (analog to digital converter) to convert this signal to work with the dbw setup (at least that is the path I am going down). I haven't looked at how the dbc works, but I assume it would be similar.
Thanks, I thought it had to be something like that. Its looking like a couple switches are in the mix for my cruise.
Thanks for the response.
Have you worked out the brake switch or relay you are going to use for TCC? I bought a 4 pole gm switch and it looks like it will fit but haven't studied wiring on it much yet.
