1994 brake booster replacement
Helena MT
I have the old booster out. Does anyone know if loosening the driver side engine mount is sufficient to give required space needed to pry engine over? Did you folks use a cherry picker or just a pry bar? Thanks!
I took the nut off the engine mount. Put a floor jack with a wood block under the oil pan. Then used a pry bar to help separate the engine mount.
[/QUOTE
You shouldn’t need anything to move for a brake booster. It takes a little effort, but it goes in without all the extra work of raising things.
