So I just replaced the HG on my 93. I sent it out and had it preasure tested and all that good stuff the install went good. When I started the truck it seemed to have kind of a miss. After I ran it for a while the check engine lite came on, I shut it down and check all the fluids and connections all looked good. Started it back up and ran it about 30 minutes at idle it seemed to smooth out and i finished bledding the air out of the cooling system. then I went for my first test drive and it ran good but seemed to shuder a little on take of but otherwise was fine. The second lap around the block i pulled away from a stop sign and the truck took off and then died. Now it cranks but it sounds like my 22re did when the timing chain broke. I'm lost here why would it break if that is the issue? The other thing is that it never seemed to stop smoking I did not smell coolant but it was smoking like crazy. I need some help here!!!!!
.I threw a post on the Wisconsin site but it look slike not many people go on there so I will have to wait and see.
time
