1993 80 tach question
apple valley ca
Does anyone know how many pulses a 1993 fj80 tach uses. I ask b/c it could be 2, 4 or 6. Probably 6. Some oem tachs use 4. Installing 2006 6.0. GM PCM can be programmed to 2,4,6 or 8 pulses. So if I set it to 6, maybe just maybe I won't have to replace tach or remove dashboard. I'm an electronic engineer and have come up with a few circuits that hopefully will save time and money as well as retain the original vehicle appearance.
I’d be interested to know also. On white wire connector c2 pin 10, I’m getting a positive signal in which I need a ground. Maybe I’m over thinking it but I was going to steal the signal from injector 1 ground but haven’t gotten around to it.
my guess would be 6, I cant find that in the rm and im guessing that that may be info that Toyota dosnt share. if you have a volt meter that can check rpm maybe set it to 6 and check what the tach is reading against what the volt meter is reading a you cam make adjustments from there. have some resistance readings, hopfully they'll help out a bit
