1992 LC with AC issues
Raleigh
Hello,
I am new to the board. I have a '92 80 series with AC issues. I was hoping to get some feedback. I still have the R12 system. My compressor kicks in but I am still not getting cold air. I have added R12 and checked for leaks and nothing. My questions are: Does it make sense to evacuate the system (capture R12) and then draw a vacuum to draw out any moisture and keep the same parts OR does it make sense to swap out the compressor/drier/evaporator to avoid continuous trouble shooting.
I have looked at the Faqs sections and done searches on this board and others. It seems that some of the original equipment on these trucks is still working for some.
TIA, I appreciate any/all suggestions.
Jake
First off...welcome to MUD!
These A/C systems have proven to be pretty durable. Is the sight glass clear when the A/C is operating? I'm not sure where it's located on the 80's, but I'm sure someone will chime in with the location. If there are bubbles, then it needs more R12. Hooking up some gauges will help to diagnose what's going on. I wouldn't just start replacing parts without knowing they're bad.
If your water control valve isn't closing all the way it can still be running coolant through the heater core and have hot air come out.
the sight glass is right front of the radiator if you are standing infront of the cruiser. they are about the size of a 16oz beer and are black with insulation around them. what are your pressures in the a/c system? i agree with lt1fire, make sure your coolant control valve is closed all the way, heat will always overpower a/c. I converted mine to R-134a, it makes it so much easier to deal with incase of issues down the road. Also, i know around birmingham, al (where i live) most shops won't touch R-12, just because of the problems of disposing of it. Pm me if you need some more help
Thanks
Charles
I did check the water valve per the instructions on this board and it seems to be working properly... I do not see any bubbles in the sight glass at anytime. I need to check the pressures in the system and post that. I was undedr the impression that it would be better to keep the R12 system....? I understand that refrigerant is more expensive, is that the only issue? I appreciate all the insight!
Jake
Hi,
I'd try to keep the system R12. Yes it is more expensive ($28/12oz can), but it will cool better. Since it doesn't get used up, just resolve any leak issues and you're good. When you get a chance, post the gauge readings, and we'll go from there.
Rex
OK, finally back in the US and tried the AC again just to see what would happen... I get a few lights on the dash that blink on/off then go away (battery, brake and AT light). I have not done my due diligence and checked pressure but I am going to. Would the alternator cause these lights to flash? Oh BTW, still no cold air...
