First off I have been following this site since we bought our 1992 Fj80 for our son as a project, we could not have kept it going without all of the help, Thanks!
We pulled the engine and had it rebuilt because of a piston melt down before we owned it, we had the cylinders bored, new pistons, rings, bearings, and cam shaft. Our problem now is a misfire on cylinder #5, I can pull the spark plug wire without any change to the engine. I have replaced the distributor cap and rotor, replaced all wires, and plugs. I have pulled the spark plug and it is getting spark. There is carbon build up on the new plug, but it is never wet when I pull it out after running. I have taken the exhaust manifold temp on this cylinder and it is cooler than the rest. I checked compression and all cylinders are at 155 psi. I am thinking the only thing that I have left is the fuel injector, but I don't know why I would be getting carbon build up on the plug if the injector wasn't working. I have taken it to several mechanics in the area, but none want to work on a misfire because of the age of the electronic system.
Any ideas of what I could be missing? Thanks
