256k
once again my favorite toy goes from running strong to deteriorating quick. almost undriveable now in three days. had been having some bog when it shifted into 2nd until it reached about 2300 rpm, now coughing and bogging down when gas petal pressed in second, third, foutrth until it finally gets the rpm up past 2300. it's main weak coughing band seems between 1800-2300rpm. this seems to be getting worse fast. it is idling fine and sounds great, just a lag and stumbling and gets close to dying when you drive and try to put under load. almost like a dead petal until you get so far up it's asking for the 2300rpm plus zone on the petal. feels sort of like lack of sufficient fuel, or vacuum leak.
recent things done:
)new starter this week, lots of wires in this area something bumped around down there??
)new air filter this week.
)new brake booster a few months ago(runs on vacuum)
)new dist cap and rotor, wires and plugs.
)fuel pressure regulator and damper changed couple of mouths ago, but was running great up until two days ago.
been a couple of years since fuel pump changed. maybe it's failing??? about that long on the fuel filter also. don't know it fuel filter can cause this sort of problem.
please help, i been searching these threads most of the day and going nuts. tps threads, egr threads, ect.
totally disconnecting the vacuum line on the egr didn't seem to help or hurt it.
recent things done:
