For Sale 1990 Toyota Xtra-Cab, SAS, Duals, ARB's & More
Boise, ID
1990 Toyota Pick-Up Xtra-Cab
84’ Toyota Solid Axel Swap
Trail Gear Hi-Steer
Trail Gear 3” Front Springs
Trail Gear 59” Long Rear Springs
Rancho RS9000 Shocks
Longfield 30 Spline Super Axles
ARB Front & Rear Air Lockers
5.29 Gears Front & Rear
Rear Driveshaft is Brand New
Marlin Crawler Duel Transfer Cases (stock gears in both cases)
Trail Gear Dual T-Case Cross Member
Rebuilt 22RE - Approximately 7000 Miles on Rebuild, Have Paper Work and Under Warranty Until Next Summer
Heavy Duty Clutch Installed w/ Motor
Electric Fan with Aluminum Shroud
Ice Cold A/C
Power Steering
IFS Brake Calipers and Vented Rotors
Optima Red Top Battery
2.5” Exhaust with Downey Header, High Flow Cat & Flow Master 40 Muffler
5-Speed Transmission
Nice Pioneer Stereo with USB Port
Cobra CB with PA
Passes Emissions
Bobbed Bed 9 Inches
Gets Around 20 mpg and Cruises 70 mph No Problem
Almost New BFG KM2 Tires 35/12.5/17 on Black Steel Wheels
Tube Rock Sliders
Tube Front Bumper
This truck runs and drives great. Drive it down the interstate to the trail, wheel, and drive it home. The suspension on this truck works great and I have the shocks and springs dialed in. Everything on this truck works perfectly and it needs nothing! I have owned many trucks with the 22RE and this one has much more power than any of my past trucks, and with the dual t-cases it can crawl with the best of them. I have used this truck for what it’s built for, therefore, the body has a few dents, dings and scratches, but the doors seal up good and there is no wind noise or water leaks. If you are looking for a daily driver that can wheel the hardest trails on the weekends and make it back to work Monday morning this is the truck for you. Truck is located in Idaho Falls, ID. Asking $8,000 OBO. If interested give me a call 208-243-0567, Jason. Thanks for looking.
More Pics.
I am looking for a 80 myself because my family has outgrown my FJ40. If not I would have already figured out how to buy this off of you.
Truck looks real nice
GLWS
