1989 toyota dome light problem
Okay I have a 1989 Toyota 4x4. The dome light will not work. I've checked the fuse under the hood and its good and I've checked the bulb and it's good. Any suggestions on what to check next?
I haven't checked the switch. Is there a easy way to check it. I've tried it on all different locations in the switch.
Mine does something similar. Mess with it for a bit and everything comes on and then eventually it quits working again. I did two things to mitigate (not fix, but make it better). 1.) I pulled off the dome light and got a wrecking yard SR5 mp light setup. 2.) grounding. Make sure your grounding is top notch. Good luck.
