- Location
- United States
1989 4runner with a factory 3.0 5spd (new 3.0 long block 8000 miles ago), single tcase (one of the few things left to be built on the rig is to double the case)
Body is mint, NO RUST or dents or dings (hard to believe since it was me driving but it is mint)
Full Canback soft top with windows in great condition with load roof racks as well
Full factory hard top as well
SAS last year using the Trail Gear kit with 4" springs and Bilstein 5150 shocks
Rear Trail Gear kit 4" with 5150 shocks as well
Front axle has 5.29 gears, ARB, High Pinion third, Longfield shafts, warn hubs, fresh brakes, all rebuilt new bearings, tie rod is behind the axle using 4xlabs high steer arms
Rear 6cyl rear axle with 5.29 gears ARB low pinion with Full Float conversion from Front Range Offroad using alloy shafts, disc brakes, Aisin hubs
Viair oba system, constant duty, with mechanical switches for ARBs (no electrical switches to go bad), includes 2.5 gallon tank
35x13.50x15 BFG Krawlers which have a whopping maybe 1000 road miles wrapped on 15x10 beadlocks
Rock Sliders from 4xinovations
Front full bumper from 4xinovations with new Ramsey 9.5e winch with synthetic rope(no pulls on the winch yet)
Tree sliders from 4xinovations which are not yet installed (run along top edge of the body)
Know issues: Wheels need balancing as they are "weld on" beadlocks, front end has slight shimmy, I am not a toyota guy and I am sure I have the wrong torque settings on the bearings on the hubs. Title is a salvage title as it had s slight hit years ago but was repaired, all docs for NJ and PA motor vehicle included.
Included, extra beadlock kit to make a spare, hydraulic ram for hydro assist with fittings to tap box, other misc parts as well.
Looking to get $10,000 for the rig, price sounds high but you would be hard pressed to find a runner this clean on the east coast. Contact me at 908-296-7613 I will consider less if I keep the winch and OBA system
Pics here:
http://imageevent.com/holiday1304/19...0&m=24&w=0&p=0
Can get more if needed, bring the offers
Pics here:
