1988 SAS toyota crawler DD
$4500.00 obo
Nate 801-836-0491
For pics e-mail freedomrocker@hotmail.com
pics at http://www.ksl.com/index.php?nid=218...&lpid=&cat=402
SAS with an '85 front axle This truck can be a daily driver.
Housing supported with Trail gear axle truss and plate
Inner axles are Bobby Long's 30 spline Longfields (wow, these are awesome!!!)
4 cyl 3rd w/ 5.29 r&p heat treated by Bobby Long and an Aussie Locker
Trail gear high steer
V6 brake calipers w/ upgraded vented rotors and braided extended Brake lines
4" Trail Gear leaf springs w/ Bilstein 12" shocks mounted on custom shock hoops
2.5" aluminum spacers
Rear end:
88 rear housing (wider than pre '86 years)
V6 third w/ 5.29 r&p gears with a Lock Rite for traction
5" Trail Gear leaf springs inboarded to match the front springs. Flexes great, and provides a platform to go Formula Toy in the future!
Bilstein 14" travel shocks custom mounted out-board of the springs for excellent side-hilling
Pinion angle changed to point straight at T-case
3.0 L V6 engine (3VZE), runs great and starts quickly!
Stock transmission and transfer case
Interior:
Removed stock bench and put in Camry seats for extra comfort (My wife will actually ride in the truck with me now )
CD player
CB
Custom gauges including tachometer, oil pressure, and voltmeter (oil and voltage are from an SR5 cluster and need to be wired, but they are mounted)
A/C works awesome! Make all the buggy guys jealous when it's 100+ outside.
Exterior:
Custom body armor as described below
rear LED/custom lights
Rear tube bed sheeted out with aluminum tread plate (80% done, truck will come w/extra tread to finish job)
3 Fog lights front w/ lights over front wheels for night runs
2 Fog light rear
custom high-lift mount w/high lift!
Armor:
Custom front bumper w/ winch mount by Rock-Logic
Custom rear bed by Rock-Logic
Custom sliders mounted so the doors just barely clear for extra clearance
Custom T-case cross member (hangs only 2 or so inches below frame)
so where you be? 801 isnt showing on areacode search.
