SOLD 1987 Suzuki Samurai, West of Kansas City, $9000 OBO
KC, MO Area (again)
Price drop to $8000.00. Willing to work with a buyer. I have sold the bikini top. I have a full, soft top that will be sold with it.
Well Built 1987 Suzuki Samurai. It isn’t a beauty plate but its hell for stout. Additional pictures available on request. I just added what I have available.
Engine – 1.6, 16v from Geo Tracker. Engine has around 80k miles on it
Clutch – Trail Tough. Replaced clutch package along with throw out bearing during the engine swap.
Transmission – stock 1987 Suzuki Samurai
Transfer case – Stock Case with Trail Gear 6.5 gear set, updated front output gear. I used a full rebuild kit when I installed the gears. T-Case is in a Zuks Off Road 17/14 bolt SUPER Snatch t-case cradle kit and the Panty Liner (ZOR and their names for stuff).
Axle, Front – 1978 Toyota Land Cruiser (Fine Spline) with Aussie locker. I did a knuckle rebuild on the front axle before installing it. Front axle has stock disk brakes. I took the breaks apart, cleaned them up before I put the axle back together. I deleted the dust cover.
Axle, Rear – 1978 Toyota Land Cruiser (Fine Spline) with Aussie Locker. The rear axle has drum brakes.
Steering – Tracker/Sidekick power steering pump feeding a Toyota IFS Gear Box. Pitman arm is from Marlin Crawler drilled for an FJ80 tie rod end. 4×4labs Frombe Steer – High Crossover Steering System. Driver side arm is ready for hydro assist.
Lift - SPOA Suspension with Front and Rear Missing Links from Trail Tough with "Bonz-Eye" YJ Springs on all 4 corners. Front shocks are FOX 2.0, rear are CALMINI shocks, 18mm shafts, polyurethane bushings, twin tube hydraulic design. Because of the springs and placement of the spring perches, the wheel base is longer. I tried to measure it myself and came up with 85”.
Tires/Wheels – 38.5” x 11” r16 Super Swamper Boggers on FJ80 Toyota Land Cruiser aluminum wheels, 16” x 8” six lug on 5.5” center
Body – Interior is lined. I do have a rear seat in great shape. Passenger seat is in better than average condition, Driver seat does have a tear in it. All Gauges work. Dash lights do not work. I think a ground wire is loose or off. Radio does work, CD player eats CDs.
Body – Exterior. I consider it in good shape. There is rust below the fuel cap on passenger side. Small rust bubbles are starting at top of the tub, at the corners, below the front windshield. A couple of the fender flares have come off. It does have some scrapes and scratches from wheeling. I do have the doors for the Samurai.
It does have a radio and 4 speakers. The CD player started making noise so I haven’t used it in a while.
I do have many extra parts and pieces. Full and bikini top, extra soft top parts
Asking $9,000. THAT SOMEONE BUY THIS! If you don't like this price, let’s talk. It's easy to justify this price, but at the end of the day it's worth what the buyer and seller agree to!
I have to sell this. I don’t need any help selling this, thank you. It kills me to sell it.
PM Me or send email to j r e ll m a k e r AT ya hoo dot you know the rest
Thanks for looking,
Rob
Just a few more pictures.
Bump
OOPS. Odessa, MO is east of KC. Not west.
I could remove/replace items to bring the price down.
Replaced with a 4.16 Tcase and reinforced long side Tcase arm.
Replaced with steel wheels and rollers
Remove all extra parts. Provide one or no top.
At the end of the day I will take a loss on this rig. I realize it. If your intrested drop me a line. Lets talk it over.
Thanks again,
Rob
Bump. I need to sell.
Motivated to sell. Give a call six six O - two three to - for too 5 0. Lets Talk!
Bump. MUST SELL.
So, what is it worth?
Bump.
