- Location
- United States
1985 FJ60, 33" BFG AT's on 16" Stockton steel rims(@$300 ea)...5 mounted BFG's & 6 rims total, U bolt flip up kit front and rear, rebuilt front axle with ARB locker and 4:11 Sierra Gears, TLC 4 piston brake calipers up front, rebuilt rear axle with ARB locker and 4:11 Sierra Gears, Tranny/transfer case overflow kit installed, Old Man Emu suspension, Heavy duty sway bar up front, engine rebuilt by previous owner before it hit 200K... I have owned the truck since 2001 and it continues to be a strong runner on a daily basis... there is just shy of 260k on the clock now, replaced starter in 2003, weber carb, MAF carb spacer, replaced H2O pump and fan clutch last year, will be replacing power steering pump, replaced clutch slave cyl. this summer and have new master in the box ready to go, SOR smog pump eliminator pulley with grease fitting, replaced balanced flywheel pulley and front seal 2005ish, Optima battery, ARB on board compressor, MAF ceramic headers, exhaust with free flow cat, snorkel bolted on but not hooked up, Aussie 42 gallon fuel tank, ARB front bumper with 10,000lb Warn winch and IPF driving fog lights, IPF headlights, Aussie rear bumper with tire and jerry can swing outs, Aussie rear view's, Hannibal roof rack with dual jerry can holder including 2 H2O cans, diamond plate decking, shovel bracket, pop up tent and fold out side awning attachment's, SOR carpet and felt inside, SOR bottom seat foam driver and passenger, SOR Tough Duck upholstery, AC retro kit, AC worked all summer in Charleston S.C., Headliner is in great shape, body has some dings and rust spots but nothing a little sheet steel and time with a tig torch won't cure, frame is solid, will cruise down the highway @ 60-65mph revving 2800ish, MPG 13-16ish depending on fuel additives, load, and driving style, currently my daily driver for the past 2 years, Have smog pump as well as various other old and new replacement parts... old carb etc... Located in Allentown Pa. $12,900... Girlfriend and dog not included...
Has Alpine stereo with amp but it is not hooked up, fresh engine mounts 2 years ago, replaced front marker lights, was repainted by previous owner, I have a spare cover for the tent, I run 15 W 40 diesel oil with a can of Lucas every 3000K or so with K&N oil filter, K&N air filter as well, The rack is currently off the truck and in my house, Sure there is more that I forgot...
