1983 Fj-60
Status
Not open for further replies.
Lost Coast of California
Smogged & Legal.
Currently has 159,6++ miles on it.
This is what I have done to it while in my possession. All modifications & or repairs performed by me.
Engine stuff,
Done at 134,840
New head gasket, New head bolts, Cylinder head overhauled (Cleanup mill of .003” 3 angle valve job, new freeze plugs & new valve springs) by Wally’s machine in Eureka, Ca. Coolant flush & new coolant. Replaced all vacuum lines (over 40 feet), Replaced broken emission parts such as two BSBV’s, two VSV’s, HAC module, gulp valve, Etc. Resealed oil pan & side cover. New thermostat housing, K&N air filter. Tune up done last may. Cap, Rotor, Spark plugs, Fuel ilter, Etc.
Chassis stuff,
Transmission, Transaxle, Front & rear differential fluids drained & refilled with Valvoline 90 Wt Gear oil, Replaced Clutch slave cylinder, Replaced bearings & Repacked front knuckles. Installed front & rear long Add-A-Leaf springs, installed 2.5” Longer rear shackles & polyurethane bushings making for a 3-1/2” front and a 4-1/2” rear lift total, Installed Hell for Stout shocks. Lowered front sway bar mounts to align anti roll bar (sway bar) after lift. Yokohama Geolander AT+II 31”X10.5”X 15” tires (Includes -matching spare).
Body/ Interior,
Aussie mirrors, 4 & 7 way trailer wiring & 2” Class 2 receiver hitch, New dome light, Shifter ball, 3 way rear seat belts, Summit Racing gauge set (Water temp, voltmeter & Oil Pressure Stock Gauges work fine), New rear lift assist shocks, Pioneer CD head unit Front & Rear speakers (nice sound). New front door seals new front windshield & seal.
The bad,
Has rear wheel well rust where the mud flaps bolted on, Rear tailgate starting to rust through. The A/C is low in refrigerant & needs to be recharged with R-12 or you can change over to HC-12a ir R-134A
I have plenty of pictures available on request. Please let me know if you have Dialup so I can reduce the image Quality.
I live in Eureka, Ca and can deliver the vehicle from Redding to Sacramento, Eureka to Ukiah, West Sacramento to Suborn south to angles camp.
Asking 3500.00.
Status
