1983 BJ46 / 3B question
Temecula, California
Hello you guys, I’m not a mechanic. My diesel mechanic has retired. Any advice on this issue would be helpful. The 3B won’t start. It cranks, it blows out some black smoke, it’s getting proper fuel, the fuel injection pump was recently rebuilt properly and installed properly ( the no start issue started before the injection pump rebuild ), the injection pump timing ok, the super glows are all tested and operating properly, the batteries are new, starter cranking properly, no water in the system, diesel fuel is new, fuel lines clean with fuel properly getting to the engine, the current compression ( tested 2 times ) is 350-300-350-300 psi. Any advice as to what I should do next you guys? Any input would be greatly appreciated. My diesel mechanic was able to do the above testing. Just didn’t get any time to investigate further. Thanks you guys, Dave / FJFJFJ
