Looks can be deceiving. The gear reduction starter that came along with the 1983 FJ60 2F engine I bought three plus years ago looks clean on the outside. The fellow had his mechanic hook up the starter so we could do a compression check, engine sitting on the ground. He had a little trouble getting it working, seems like he dipped a screwdriver into the crankcase to get some oil and then put that in the end of the solenoid, but he got it to work, we checked starter rotation compression and it went back into the box where it remained all this time.
With The Beast pretty well squared away I pulled out the starter to take a look at it. On the bench, using a lawn mower battery (5 A) I used the frame for ground. At the solenoid spade the gear jumped right out. On the motor it turned. So I installed it. While it did try to do something it was more of growling noise like you get with a low battery. I put the old starter back in and it fired right up. So I took the GR starter apart. You can see that it was full of crud and corrosion. Once cleaned up the bearings are fine, just need to be greased. The commutator cleaned up fine, cleaned between the segments. But the solenoid contacts have the wear trench although the disc looks good. The brush plate has one broken spring. There are no numbers, or any product information anywhere on this starter. I look on maniacelectricmotors.com and "think" I have identified the parts, but not sure. Any help or advice would be greatly appreciated.
