1982 Toyota 22R Alternator Adjustment Bracket
Dallas, TX
Okay, here I am once more trying to figure out my brackets. My truck is a 1982 Toyota pickup with the 22R engine with the power steering pump above the alternator. The truck has been apart for 5 years and I am finally getting around to putting it together. I can not for the life of me figure out where the top alternator bracket bolts on the engine. Maybe I am missing parts, but Toyota and the local auto parts are of no help. Anyone out there that can help, I would be grateful. Are there spacers or what?
Thanks
Hahaha!
The slotted end mounts to the top of the alternator. From there the same flat side mounts to the 14mm bolt on the top of the timing cover.
90 degrees to the other end, it mounts along with the dip stick to the side of the block!
None of you guys could give up this easy answer? :flipoff2:
@WristPin check a few threads down :flipoff2:
